# ./demo_ipc -c 4  -r ./ -t "release_2_1684223654_55nqyc8_bay1682404375438v046"
SDK Version:< TUYA IOT SDK V:1.0.6 BS:40.00_PT:2.2_LAN:3.3_CAD:1.0.4_CD:1.0.0 >
< BUILD AT:2023_05_12_12_20_17 BY ci_manage FOR ty_ipc_wr_wl_linux_sdk AT gcc-arm-92-201912-x86_64 >
IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:1 SHUTDOWN_MODE:1 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:1 OPERATING_SYSTEM:100 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 >
========================================== start
s_ipc_pid: z0zt7h61bxaxnnaw
s_ipc_uuid: uuidebe1c13b8ad163a0
s_ipc_authkey: RyhWMQCnXQ1n1yuyaGUHACtnXVliGHNv
========================================== end
sdk start
[01-01 18:12:15 TUYA Debug][tuya_ws_db.c:450] init fs. Path: /tmp/
[01-01 18:12:15 TUYA Info][kv_storge.c:45] Init Kvs With File:/tmp/
[01-01 18:12:15 TUYA Debug][simplekv.c:924] path:/tmp/
[01-01 18:12:15 TUYA Debug][simplekv.c:960] get encrypt_key[▒▒▒US▒▒▒▒ykR▒▒]
[01-01 18:12:15 TUYA Debug][simplekv.c:978] normal file exist. bak file not exist
[01-01 18:12:15 TUYA Debug][simplekv.c:291] size in: 0 and final: 28700 And mag_rec_max: 512
[01-01 18:12:15 TUYA Debug][simplekv.c:306] create data hd success
[01-01 18:12:15 TUYA Debug][simplekv.c:1034] read from normal file
[01-01 18:12:15 TUYA Debug][simplekv.c:746] curr db is V2. No need to upgrade
[01-01 18:12:15 TUYA Debug][simplekv.c:536] head check success
[01-01 18:12:15 TUYA Debug][simplekv.c:639] read and check head success
[01-01 18:12:15 TUYA Debug][simplekv.c:1054] read from normal file success
[01-01 18:12:15 TUYA Info][uni_thread.c:219] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 18:12:15 TUYA Debug][simplekv.c:1090] init from normal file success.
[01-01 18:12:15 TUYA Info][mqc_app.c:355] mqc app init ...
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:300 cnt:1
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:302 cnt:2
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:304 cnt:3
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:307 cnt:4
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:308 cnt:5
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:312 cnt:6
[01-01 18:12:15 TUYA Debug][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[01-01 18:12:15 TUYA Debug][uni_thread.c:247] Thread:sys_timer Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA Info][uni_thread.c:219] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[01-01 18:12:15 TUYA Debug][uni_thread.c:247] Thread:cmmod Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:5 cnt:7
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:31 cnt:8
[01-01 18:12:15 TUYA Debug][svc_online_log.c:295] svc online log init success
[01-01 18:12:15 TUYA Err][log_seq.c:869] logseq empty
[01-01 18:12:15 TUYA Info][uni_thread.c:219] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[01-01 18:12:15 TUYA Debug][uni_thread.c:247] Thread:wk_th-0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA Debug][simplekv.c:1188] read key:gw_bi isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1228] find key:0 gw_bi
[01-01 18:12:15 TUYA Debug][simplekv.c:1257] key:gw_bi find value.Len:192
[01-01 18:12:15 TUYA Debug][ws_db_gw.c:159] gw base read finish:0
[01-01 18:12:15 TUYA Notice][tuya_iot_wifi_api.c:274] wifi soc init. pid:z0zt7h61bxaxnnaw firmwarekey:(null) ver:1.2.3
[01-01 18:12:15 TUYA Debug][tuya_svc_upgrade.c:787] tuya svc upgrade init success!
[01-01 18:12:15 TUYA Notice][tuya_devos_entry.c:1639] Last reset reason: 255
[01-01 18:12:15 TUYA Debug][tuya_tls.c:326] tls register constant uuidebe1c13b8ad163a0 RyhWMQCnXQ1n1yuyaGUHACtnXVliGHNv
[01-01 18:12:15 TUYA Debug][simplekv.c:1188] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1224] no key find
[01-01 18:12:15 TUYA Debug][simplekv.c:1271] __read_kv_raw fail. -3
[01-01 18:12:15 TUYA Debug][simplekv.c:1305] __read_kv_with_decode fail. -3
[01-01 18:12:15 TUYA Debug][tuya_tls.c:269] load tls_ca_cnt fail. no ca in local db
[01-01 18:12:15 TUYA Notice][tuya_devos_entry.c:1128] serial_no:null
Set Country Code:(null)
[01-01 18:12:15 TUYA Debug][simplekv.c:1188] read key:gw_wsm isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1228] find key:1 gw_wsm
[01-01 18:12:15 TUYA Debug][simplekv.c:1257] key:gw_wsm find value.Len:144
[01-01 18:12:15 TUYA Debug][ws_db_gw.c:291] gw_wsm read success
[01-01 18:12:15 TUYA Notice][tuya_devos_entry.c:1159] gw_cntl.gw_wsm.stat:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1188] read key:wf_start_md isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA Err][tuya_devos_netcfg.c:589] read wf start mode err:-6
[01-01 18:12:15 TUYA Debug][tuya_devos_netcfg.c:635] <__gw_upd_nc_type> wf start mode change:-6, 0->0
[01-01 18:12:15 TUYA Notice][tuya_devos_netcfg.c:1290] gw_cntl->gw_wsm.nc_tp:2
[01-01 18:12:15 TUYA Notice][tuya_devos_netcfg.c:1291] gw_cntl->gw_wsm.md:0
[01-01 18:12:15 TUYA Debug][uni_network.c:424] set_dns_cache_priority:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1188] read key:gw_di isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1228] find key:2 gw_di
[01-01 18:12:15 TUYA Debug][simplekv.c:1257] key:gw_di find value.Len:320
[01-01 18:12:15 TUYA Debug][ws_db_gw.c:454] gw_di read success
[01-01 18:12:15 TUYA Debug][simplekv.c:1188] read key:is_stride isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA Debug][tuya_devos_entry.c:782] stride from flash: 0.
[01-01 18:12:15 TUYA Debug][tuya_devos_entry.c:789] no actived, no upgrade:0
[01-01 18:12:15 TUYA Notice][tuya_devos_entry.c:1213] gw_cntl.gw_if.abi:0 input:0
[01-01 18:12:15 TUYA Notice][tuya_devos_entry.c:1214] gw_cntl.gw_if.product_key:z0zt7h61bxaxnnaw, input:z0zt7h61bxaxnnaw
[01-01 18:12:15 TUYA Notice][tuya_devos_entry.c:1215] gw_cntl.gw_if.tp:0, input:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1188] read key:gw_ai isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA Debug][simplekv.c:1228] find key:3 gw_ai
[01-01 18:12:15 TUYA Debug][simplekv.c:1257] key:gw_ai find value.Len:368
[01-01 18:12:15 TUYA Debug][ws_db_gw.c:579] gw_ai read success
[01-01 18:12:15 TUYA Debug][uni_network.c:438] set_dns_region:1
[01-01 18:12:15 TUYA Debug][tuya_devos_entry.c:1661] enter success_proc
[01-01 18:12:15 TUYA Debug][tuya_devos_health.c:37] init watchdog, interval: 60
[01-01 18:12:15 TUYA Debug][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[01-01 18:12:15 TUYA Info][uni_thread.c:219] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:11 cnt:9
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:41 cnt:10
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:100 cnt:11
[01-01 18:12:15 TUYA Debug][mqc_app.c:149] mq_pro:27 cnt:12
[01-01 18:12:15 TUYA Debug][uni_thread.c:247] Thread:health_monitor Exec Start. Set to Running Stat
WIFI Get MAC D4-9C-DD-90-33-A2
[01-01 18:12:15 TUYA Debug][tuya_devos_netcfg.c:1040] nc_tp:2, md:0
[01-01 18:12:15 TUYA Debug][tuya_devos_netcfg.c:1258] lowpower timeout has been set to 900000 ms.
[01-01 18:12:15 TUYA Debug][netcfg_module.c:132] type:0x10002,is_set:0
[01-01 18:12:15 TUYA Debug][netcfg_module.c:132] type:0x10002,is_set:1
[01-01 18:12:15 TUYA Debug][tuya_iot_wifi_api.c:403] register wifi network monitor. interval:1
[01-01 18:12:15 TUYA Debug][tuya_devos_netcfg.c:779] ssid:tuya
[01-01 18:12:15 TUYA Debug][tuya_devos_netcfg.c:780] passwd:tuya
Exec Cmd:ifconfig wlan0 up
[01-01 18:12:15 TUYA Debug][tuya_devos_netcfg.c:781] token:release_2_1684223654_55nqyc8_bay1682404375438v046
[01-01 18:12:15 TUYA Debug][tuya_ipc_sdk_simple_start.c:194] tuya ipc sdk start is complete
TUYA_IPC_SDK_START success
THREAD_ALBUM_SEND start...
WIFI Set Mode 4
Start AP SSID:SmartLife-33A2
[01-01 18:12:15 TUYA Debug][ap_netcfg.c:800] start ap success:SmartLife-33A2
[01-01 18:12:15 TUYA Debug][netcfg_module.c:368] netcfg module start type:0x10002
[01-01 18:12:15 TUYA Err][wifi_netcfg_frame_transporter.c:410] timer is not run,wait
[01-01 18:12:15 TUYA Notice][tuya_devos_netcfg.c:369] stop ap cfg mthd:4, ret:0
[01-01 18:12:15 TUYA Debug][ap_netcfg.c:899] ap cfg start:65538
[01-01 18:12:15 TUYA Info][uni_thread.c:219] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:18432,priority:5
[01-01 18:12:15 TUYA Debug][netcfg_module.c:115] start 0x10002 ret:0
[01-01 18:12:15 TUYA Debug][uni_thread.c:247] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[01-01 18:12:16 TUYA Debug][tuya_iot_wifi_api.c:369] wifi netstat changed to:6  -->>
[01-01 18:12:16 TUYA Debug][tuya_ipc_sdk_simple_start.c:71] Net status change to:6
[01-01 18:12:16 TUYA Debug][user_main.c:119] Net status change to:6
[01-01 18:12:16 TUYA Debug][tuya_iot_wifi_api.c:372] wifi netstat changed to:6  <<--
xxxxxxx s_mqtt_status: 0 xxxxxxx
